Best DVD recorder for about £250??
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bigweed, Jun 16, 2004.
  1. Bigweed
    Bigweed
    May 5, 2004
    120
    16
    Bournemouth, UK
    Hi to all viewers
    I have just had my VCR break down again, and have decided to buy a DVD recorder. I was wondering what was the best model for about £250?? I would need good PQ, not too worried about sound capabilities as only TV speakers will be used. Also, PAL progressive and component out would be very handy, as would -RW recording and playback. Can anyone help??
    Bigweed
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,082
    Warwick
    +2,935
    The Toshiba DR1 or JVC DMR10 both meet your requirements. They record to DVD-RW, DVD-R and DVD-RAM. The only limitation to each is that they cannot accept an RGB input - significant if you want to record in high quality from a set-top box from Freeview, Cable or Sky.
    If you were willing to consider dropping DVD-RW recording then the Panasonic E55 (which does have RGB in) is an excellent option.
  3. Bigweed
    Bigweed
    May 5, 2004
    120
    16
    Bournemouth, UK
    Are there any HDD/DVD recorders in this price range - I know its asking a lot!!!
    Bigweed
  4. Fred Smith
    Fred Smith
    Apr 23, 2004
    2,207
    Reading
    +371
    Thats just being silly!
  5. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    wait till christmas!
  6. Bigweed
    Bigweed
    May 5, 2004
    120
    16
    Bournemouth, UK
    So is it just the JVC and Tosh that meet the requirements, or are there any others? RGB Scart would be very useful...
  7. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Tosh DR2 out soon which is the RDXS32 without a HDD.
    Should imagine that will fit your bill. For an extra £100 on your budget you could get a HDD with the RDXS32 at £355 (using beat price match by a tenner with QED-UK) at Richer sounds.
  8. Bigweed
    Bigweed
    May 5, 2004
    120
    16
    Bournemouth, UK
    I was considering getting the Sony DVP NS730 DVD player for a while, just wondering how the PQ on the Tosh DR1 compares with the Sony, if anyone has seen both??
    Bigweed
  9. Bigweed
    Bigweed
    May 5, 2004
    120
    16
    Bournemouth, UK
    What about upto £300? Can I get anything with RGB in for that amount, plus RGB out, -RW recording (video/VR modes), good PQ, NTSC playback?
    Bigweed
  10. Rasczak
    Rasczak
    Apr 3, 2002
    22,082
    Warwick
    +2,935
    Your still looking at the same machines: Toshiba DR2 or the JVC DMR10. Also the Panasonic E55 if your willing to go without DVD-RW.
    The market is quite clearly split with DVDR 'standalones' being around the £200-£300 range and HDD/DVDR combos starting from £400. Generally the more expensive of the former are models that have iLink (for digital camcorders) and multi-media inputs (such as the SD/PC Card inputs on the Panasonic E65) - so adding £50 to your budget doesn't bring up any amazing new option. Most DVD- models now support RGB input with the exception of JVC (who will add it from next year). Panasonic, Toshiba and JVC all offer progressive scan output.
