Best DVD player for around £700
Discussion in 'Blu-ray & DVD Players & Recorders' started by BigScreenAl, May 20, 2002.
  1. BigScreenAl
    BigScreenAl
    May 20, 2002
    78
    9
    Derby, England.
    Looking to spend around £700 on a DVD player what is the best one? I like Pioneer kit but it's usually a bit on the big side, anyone seen a 939A?
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,687
    UK
    +116
    Tosh SD900e for £699 - www.leconcepts.com
    If you also want good CD, try the Arcam DV88....
    JJ
  3. ROGER B
    ROGER B
    Got to agree with Jason
    ive just got a Sd900e from leconcepts and its the dogs.
    havent had chance to try any rce or dvd-r disks with it yet but im informed they should both work fine with the new mod.
  4. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Got mine from leconcepts and can confirm RCE is no probs and DVD-R is great too :)
