Best DVD player for around £200 ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by PapAV, May 10, 2002.
  1. PapAV
    PapAV
    May 10, 2002
    187
    +15
    My PS2 isn't really up to the job. (grrr.....sync probs!)
    I'm thinking about the Sony DVP700 or maybe even pushing the boat out to the 900?
    Ideally I'd like it to play as many formats as possible and be the best quality (duh!)
    My setup;
    Philips 36PW9607C (arrives next Friday)
    Sony QS DTS 5.1 amp
    4 x Tannoy Mx Floorstanders
    1 x Tannoy Mx Centre
    another Sony Amp powering a JBL Sub.
  2. Desperado
    Desperado
  3. PapAV
    PapAV
    May 10, 2002
    187
    +15
    OK then
    checked out the philips player and it looks pretty good
    which is better for sound and picture quality?
    Philips Q50 multiregion £238
    or
    Sony DVP-S725D multiregion £299
    is the sony worth the extra £60?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Save your cash and buy a pioneer DV444 from www.hifibitz.co.uk or click the top right of your screen. Brilliant service excellent player and looks soooooooooo good. Why spend another £100 odd quid unless you need progressive.
    Just my two euros!:D
  5. Ricky27
    Ricky27
    Feb 8, 2002
    1,970
    Norwich
    +217
    Why not look at the Toshiba 510e?
  6. fonzie
    fonzie
    Save a little money and go for the Yelo DVD800 from www.lynxdv.com/
    Plays all formats of CD/VCD/DVD/DVD-R/RW
    Have purchased myself from this Company, Great Prices,Great Products,Great Service.
    Thoroughly recommend them.
    Kindest regards
  7. Desperado
    Desperado
    if u want quality (what hifi sound vision*****stars)
    and awsam looks what can i say the Philips Q50 is the 1 !!!!!!
    and also Multiregion @ www.unbeatable.co.uk
    DESPERADO
    forget the Pioneer 444 it cant play CDR
  8. PapAV
    PapAV
    May 10, 2002
    187
    +15
    This trying to narrow down my options post hasn't really worked.
    300 quid is my top limit
    i still think it's between the philips and the sony
    and i think the sony 900 is probably a better quality player.
    would I be right?
  9. Ricky27
    Ricky27
    Feb 8, 2002
    1,970
    Norwich
    +217
    so why not the Toshiba 510e?has progressive scan,dvd audio,looks good and is just the best picture quality out there for the price.
    You can buy this £400 player for £250 now.
  10. mancubas
    mancubas
    Jan 8, 2002
    514
    Derby
    +7
    510e for £250, were are you buying this from!!!
    Thx.
  11. Ricky27
    Ricky27
    Feb 8, 2002
    1,970
    Norwich
    +217
    Well,first i looked at Web electricals and saw it for £260,then gave my local Richer Sounds a call and they agreed to beat the price by a tenner.
    Then if that wasnt good enough,they gave me a three year warranty for £20!!With an option that if i decide to upgrade within three years they would give me £125 back.
    couldnt believe my luck.
    Player is multiregion ready.
  12. petrolhead
    petrolhead
    Mar 29, 2002
    4,794
    87
    Newcastle
    +116
    Which RS? ricky
  13. Ricky27
    Ricky27
    Feb 8, 2002
    1,970
    Norwich
    +217
    Any RS store will do this deal for you,internet or Store,my local store is Norwich.
    Prefered to buy local so i didnt have to send it away if i had any problems.
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Do you know this from experience as my 444 states it will play CD-R. What format were you using MP3 etc. I i am going to borrow a couple of SVCD's tommorrow from a mate.
  15. mancubas
    mancubas
    Jan 8, 2002
    514
    Derby
    +7
    Cheers for the reply, I would also like to know which Richer Sounds you managed to get this great deal from, I am also going to have a go.
    How do you personally rate this DVD player?
    Thx.
  16. Ricky27
    Ricky27
    Feb 8, 2002
    1,970
    Norwich
    +217
    Hi there,
    The branch i bought from was Norwich,just give them or there mail order branch a call,tell them that web electricals have them for 260 and they will call them to confirm stock,and thats it.
    My 510e is simply a treat to use and view,fantastic pictures,great audio,and the on screen menus are great too.
    I tried prog scan on NTSC material and was impressed by the smoothness of the image,but to me it seemed to make it a little too soft,especially compared to interlaced PAL dvd's.
    But whatever you use it for the quality really is there,PAL dvd's via component is very clear and sharp on my Projector and TV.
  17. jag
    jag
    When I bought mine beginning of this year I was originally going for the Tosh 210 but the chap at Superfi said he heard problems with it and recommended the 444 at a similar price.
    Never had any problems with my 444 and at £199 MR (£10-20 cheaper now) I think its great value.
  18. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,605
    7
    167
    Birmingham, UK
    +10,474
    Question for you - someone has asked whether you are affiliated with HiFiBitz since you always seem to reccommend them. Please clarify the situation.
  19. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    No not at all but the best online supplier i have ever dealt with!!! They are quick, efficient & COMPETITIVE. I am all for good prices but I have had nightmares with others. SO no I am not affiliated, but if anyone from hifibitz or another store want to give me a job PLEASE PLEASE PLEASE PM ME.:D :D :D
  20. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Spectre,
    I am afraid that I am also frequently recommending Hifibitz as well. I have bought several things from them and have always found them very helpful when I place orders, pay for the goods and change my mind and want something else instead.
    Like hornydragon, I have no affiliations to anyone in the industry but try to patronise forum sponsors whenever possible.
  21. Squirrel God
    Squirrel God
    I believe Horny Dragon is in fact a poor student, given some of his other posts.
  22. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Indeed I am hence the plea for a job.
    Any offers
    No:( :( :( :( :( :(
  23. conington
    conington
    Mar 6, 2002
    259
    Colchester
    +6
    Webelectricals are now advertising the Tosh SD510E at £239.95. Noticed the change on Friday (gutted as I paid £259.95 2 weeks ago from Webelectricals).
  24. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Did you use a Barclaycard?
  25. Squirrel God
    Squirrel God
    Doesn't matter if they did Horny. Barclaycard only price match if it is advertised lower elsewhere. If it's the same store, they won't price match :(
    Chin up, Conington. It's only £20, and you got it 2 weeks earlier :) Welcome to the whacky world of consumer electronics where prices fall more frequently than a hooker's knickers :D
