Quantcast
best dvd player for £800
D
Dom Rice
I have about £800 to spend on new dvd player.
What would be the best model to go for?
It will be connected to a Projector so prog scan would be nice.
Any idea welcome.
Jasonjo
Denon 3800 can be found on the web for £769 - £799...new firmware should be out soon which will make this one of, if not THE best player for around £1000RRP
Also check out the Arcams if you can push the budget...
JJ
G
graham.myers
pray tell who has the 3800 for 769 and do they have stock?
G
graham.myers
Typical, I found out somebody is doing the player cheaper than where I've ordered it from and the delaer rings me this morning telling me the player is now in stock.:rolleyes:
D
Dom Rice
Thanks guys.
These two players mentioned seem to fit the budget nicely.
Does NTSC progressive scan for the toshiba mean that prog scan on region 2 discs wont work?
G
graham.myers
Correct.
In order to play Pal diiscs wiht a progressive output the player must support pal progressive.
G
graham.myers
Yes it is. Reason why I bought it. so is the Arcam DV88+
D
Dom Rice
look like the denon is the one then. It will also have the benefit of match the AVC11sr amp I have.
Cheers.
G
graham.myers
If you do go for the Denon make sure you get the correct version of the firmware. there are some that tend to make the board blow and if you do this post purchase your warranty will be worth squat.
I've got mine pre-hacked to it was the dealer taking the risk :)
there is a thread on the forums asking for version no.s that work.
D
Dom Rice
How do i know what firmware version the dvd player will be. And how do I get different firmware versions if need be?
Is the firmaware to correct the chroma bug issue I have read about?
Regards,
dom.
G
graham.myers
If you do a search there is a thread discussing this. It opens with the instructions on how to check the firmware version.
have a browse in there. It is to fix the chroma bug amongst other things. It also is for making it multi region and pal progressive.
G
graham.myers
My dealer rang me on Tuesday saying the Denon Rep was coming in Friday with the new software update. Picking it up on Saturday wooo hoo
G
graham.myers
I'll post the version no onto the other thread when I get chance. The wife is in hospital from tomorrow so I'll be spending the next 2 weeks comuting to the hospital :(
Trending threads
