Best DVD Ouput To Plasma TV?
Discussion in 'Projectors, Screens & Video Processors' started by LeeS, Feb 12, 2002.
  1. LeeS
    LeeS
    Hi folks,
    I'm thinking of buying the Panasonic TH42PW4B plasma set and I'm still not sure of the best way to drive it from a DVD player. Let's suppose that I'm going to buy a new player: what should I buy and what's the best way to connect the two? Prog scan? Component? RGB? Line doubler, IScan, RGB2VGA converter? Given the inputs on the Panasonic set what should I go for for optimum quality from both PAL and NTSC discs?
    Thanks,
    Lee.
  2. Tony Gamble
    Tony Gamble
    I have the 42PWD3 and I use an RGB to plasma VGA converter from John Sim at www.rgbtosvideo.com.
    It impresses me and to date I have never found anyone with a scaler or tuner who has said they are getting better pictures than with the converter - which is petty cash by comparison.
    However, I am new to this forum and here because someone pointed me to the chat about the PSM-1.
    Now waiting to see if any plasma users have tried it.
    But the VGA jobbie will also work on a digital off-air decoder and you will really appreciate the improvements it brings there.
    Rgds
    Tony
