Best DVD backup program to HD
Discussion in 'Computer Components' started by tim k, May 15, 2005.
  1. tim k
    tim k
    What program retains the full quality of the dvd with all sound track? I want to backup a few of my favourite dvds so i can play them straight off my computer.
  2. MikeFish
    MikeFish
    DVD Shrink will if you set it to 'no compression'. There are others too, but I can't think of their names.
  3. iZombine
    iZombine
    Jan 21, 2005
    873
    28
    +33
  4. tim k
    tim k
    Downloaded the decryptor.
    When decryping a dvd, it put all the files in 1 folder, there were quite a few. Is there anyway for it to recognise one file so i can add it to my library in mce2005?
  5. iZombine
    iZombine
    Jan 21, 2005
    873
    28
    +33
    I'm not sure as I don't have MCE 2005, but i tried adding a DVD to my Windows Media Player 10 Libary and it wouldn't work.
  6. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,488
    South Derbyshire
    +198
    I use DVDshrink. For MCE05 get the My Movies plugin and it will the work.
  7. MikeFish
    MikeFish
    If you put all the files in a folder called VIDEO_TS and then put that folder in a folder named after the film then MCE will be able to recognise it and play it properly (ie play thr .ifo file to include all chpaters breaks etc).
    Don't know about decryptor but DVD shrink automatically creates VIDEO_TS folders.
  8. tim k
    tim k
    That worked by naming it and adding to my videos, very clever, is there anyway to add the picture and disc info?
  9. MikeFish
    MikeFish
    If you want disc info & cover art etc download My Movies here.
    It's a great program which even get's you trailer for your films, and it's free (well the donation is optional).
  10. tim k
    tim k
    That is an excellent find mikefish. exactly the kind of program i needed. I plan on backing up all my favourite dvds and using the pc as a hub for all my dvd viewing. I think the thing media center lacks is library info/guides. really this is the crux of the program and i believe more should have been put into this. i believe bt want to make movies available on the next generation broadband using media center.
