best drive for ripping?
Discussion in 'Headphones, Earphones & Portable Music' started by sparkymarky, Feb 4, 2005.
  1. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,084
    48
    cornwall
    +32
    i am about to rip some cds to hard drive pc. Wondering which device is best to use? pioneer dvd rom dvd-116
    or phillips cdrw1610a?
    i assume the connection and delivery method would also have an influence?
  2. simon100
    simon100
    Nov 2, 2004
    319
    +11
    I don't think that the reading device has much influence on the resulting audio file. I've used both a DVD drive and CD read/write to good effect.
    However, the software that you use to rip the CD does have an effetct as well as the bit rate and the resulting file format.
    MP3 is, at the risk of offending many people, considered to be inferior to Apple's AAC format at the same bit rate. But only iPods tend to use AAC and everyone, including Sony, can use MP3's.
