Best DLP projector for £2500
Discussion in 'Projectors, Screens & Video Processors' started by Prav, Mar 7, 2005.
  1. Prav
    Prav
    Jan 6, 2002
    96
    +4
    Hi everyone,
    I'm after the best DLP projector for a budget of around £2.5k although I can stretch to £3k.
    Thing is it's all new to me and I don't know which brands / models or even specs to look out for.
    Any help is greatly appreciated!
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,079
    UK.
    +3,485
    What will your main viewing be? If it's standard definition, then you probably won't need a 1280 x 720 pj, so just look at the 1024 x 576 pjs.
    What size screen and viewing distance? Projectors have different 'throw' ratios, so one pj may fill your screen in your room, but another may not.
    Sim2 Domino 18H is a nice pj £2200 IIRC), but there are quite a few out there in your price range, so try to demo a few. If you cannot have full light control in the room, you may nee a brighter projector and a grey screen. With full light control, lumen output is less of an issue, depending on how bright you want the image to be.
    Try www.ivojo.co.uk for a list of other manufacturers.
    Gary.
  3. Prav
    Prav
    Jan 6, 2002
    96
    +4
    Thanks Gary. I'll be viewing mainly DVDs - but want it to be HD future-proofed.
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,079
    UK.
    +3,485
    hi Def is either 1280 x 720, or 1920 x 1080. Curently there are no 'affordable' 1080 pjs out there, but that might change at the end of the year.
    For a 720p DLP, you're limited to the BenQ 8700+ at around £2166 (Ivojo), and the Sharp XV-Z2000 at £2600+. Not sure what else there is at that price range. Look at Ivojo's site for more details. www.ivojo.co.uk
    Gary.
  5. seanm
    seanm
    Mar 1, 2002
    1,284
    48
    +44
  6. Mr Grumpy
    Mr Grumpy
    Jan 12, 2005
    377
    TBC
    +9
    A Screenplay 7200 would just sneak into your £2500 budget provided you can still find one anywhere now they are discontinued. I have one and it really is a very impressive machine particularly for the new price.
    The 1280 x 720 native resolution means that it's HD ready so you shouldn't have to upgrade for a while - always a bonus. Oh and it has a fantastic throw ratio too which was ultimately why I ended up taking it over the 5700 model which was unable to fill my 7' screen.
  7. spamboy
    spamboy
    I saw the sharp z2000 at the bristol show (and a load of other stuff too) If that were my budget, that's what I'd demo first.
  8. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    The Sharp XV-Z2000 is a great projector if your budget will stretch to it. I'd say picture quality is, by a small margin, better than the BenQ (processing and optics are slightly ahead) but the BenQ is cheaper and has a better warranty.
  9. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    I'd also say the Sharp z2000 new model is something to audition, it was pretty good adn possibly the best at this price range presently. I've no idea what you can screw out of the dealer though to make it fit your budget....
