New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
I live near Southampton and the LNB just blow off my elderly and rusting Freesat dish. Can anybody recommend the best (easy of fit and align, long lasting) Sat dish / LNB kit that will work with my Humax freesat box please?
Triax have a long standing reputation for producing zinc phostphate treated powder coated steel dishes that don't rust. They make sky dishes now but it's probably still too early to see if they can do that on sky dishes and it could be all the edges on the holes in sky dishes that increase the risk of rust starting & once it starts it easily spreads.
Some of the highest regarded dishes are prodelin and channel master (Skyware) they are plastic / fibreglass faces and heavy galvanised steel and made to use in the worst environments.. 60cm is ample
You should still protect nuts and bolts etc with grease.
