Best Distance Between Fronts and Screen
Discussion in 'Home Cinema Speakers' started by nheather, May 1, 2005.
  1. nheather
    nheather
    Oct 6, 2004
    15,416
    Horsham, West Sussex
    +4,561
    I'm planning a wall mounted panel and for the centres and fronts I'm thinking of using three wall mounted Canton CD50s.
    Is there a 'rule of thumb' on how far the front speakers should be away from the screen for the best 5.1 effect. The reason I ask is that I've seen plenty of pictures where the front wall-mounts have been pretty close to the screen (say 30cm or less).
    Having the speakers close will be (in my opinion) aesthetically better but I was wondering about sound seperation.
    Also, for the centre, is it better to have it above or below the screen.
    Finally, I would also consider the CD100s for the fronts, but have discounted this because they would be lower than the centre (the panel is going above a fire so will be quite high). I assuming that the fronts and centre should be at more or less the same level - is this a correct assumption.
    Cheers,
    Nigel
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    There's no general rule so you'd be best to think about aesthetics and what you're actually trying to achieve yourself. The Dolby website has some fairly in-depth on speaker placement that should be worth a read, I'm sure that DTS and THX also have information available.
    Personally, I would put the centre beneath the screen. To locate my main speakers it would be better to relate it to your seating position rather than the distance from your display. :)
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,442
    The Borders
    +2,596
    nheather
    Too many folk make the mistake of setting loudspeakers in arbitrary or 'where they look best' positions.
    Use your ears not your eyes to set out your loudspeakers.
    If possible get your kit into your room wired up and working and have a play with positioning - as eviljohn2 points out your listening position is your start position for how you set your speakers out.
    Height wise try and set the front Left, Centre and Right speakers so that the HF units are all aligned 'horizontally' and in line with your ears when seated in your favoured seat.
    Best regards
    Joe
  4. Grand Dizzy
    Grand Dizzy
    Dec 11, 2004
    311
    I was always taught it was 1.5 metres either side of your screen. But thinking about it, that's silly because screens are different sizes!
  5. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    I always thought that the speakers should set apart as close as you can get them to the equivalent distance of your listening position so that you form a triangle - if that makes sense. Not that this is practical in most UK homes.
    Pete.
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I have roughly that arrangement Pete (actually, just measured it and by chance I have an equliateral triangle like you describe with side length 1.6m) and it provides plenty of separation from the stereo pair with plenty of space for the centre between them sat on a 24" CRT. I've previously had to have the centre sandwiched directly between the stereo pair in a corner and it was rubbish.
    I think I would prefer to be sat slightly further away and go for something like a 2:3 ratio isosceles triangle with the short side between the speakers but unfortunately my bed's in the way. Moral of the story? No easy answer unless you have a dedicated room. :)
  7. Grand Dizzy
    Grand Dizzy
    Dec 11, 2004
    311
    My trouble is I have my TV in the corner of the room next to the fireplace. So when I buy my new speakers I won't have any room to fit them in (unless I sit one of the speakers right infront of the fireplace!)
    Guess I'll have to relocate my TV or something :(
  8. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Grand Dizzy, a corner placement isn't too disastrous as long as you implement it correctly. I don't think there would be any need for you to have a centre speaker as by virtue of placement both of your main speakers will be very close together. You can then either pocket the cash or spend the money elsewhere. :clap:
    Half the fun of HC is trying to integrate it into the room as there's almost always a better location somewhere that just isn't feasible to use. :)
  9. Grand Dizzy
    Grand Dizzy
    Dec 11, 2004
    311
    Thanks eviljohn!
    I do really want a centre speaker though. I want dialogue to come from the direction of the screen, not from the sides!
  10. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    I don't think you would notice this effect. What would normally go through the centre speaker is directed as a common signal through the left and right, and your perception of where the sound is coming from will be the centre.
  11. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,442
    The Borders
    +2,596
    Grand Dizzy
    You could consider the unconventional and go with a Yamaha YSP-1 Digital Sound Projector plus a decent sub; the YSP-1 even has a corner room setting..
    As Harry T2 suggests a front Left and Right only - works very well in many situations. Ensure the partnering AV Receiver has the ability to set the Centre channel to 'Off' and will mix the Centre signal into the L+R outputs.
    I often run my system in 4:1, 2:1 or 2:0 mode and its really not a problem - though your choice of L+R speakers can be important.
    Best regards
    Joe
  12. Grand Dizzy
    Grand Dizzy
    Dec 11, 2004
    311
    Interesting. I'll think about this. My instincts say that you should be able to tell the difference between a sound coming from directly in front of you, and a mono sound from two speakers either side. Ears are very clever things!
    Still, I'll consider it.
  13. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,442
    The Borders
    +2,596
    Hello Grand Dizzy
    I take it you've never listened to a Stereo system :)
    HiFi's have been able to 'fill the hole' between the loudspeakers for years and place Voices and Instruments within the 'sound stage' to recreate the space, placement and ambience of the recording studio or hall.
    I'd far rather listen to a decent Front L+R speaker pair with 'mixed' or 'phantom' centre channel over a L, C + R set-up with lower spec speakers and not enough room to fit them just to ensure I had the 'correct' number of cabinets.
    Best regards
    Joe
  14. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    I was thinking the`same' thing, Joe :D
