Best Diesel Fuel ?
Discussion in 'Motoring' started by Mac User, Jun 28, 2015.
  1. Mac User
    Mac User
    Sep 27, 2006
    4,556
    Norfolk
    +309
    There was a discussion at work about the best diesel fuel to use.. The vast majority of the people state Shell V Power .. What's your thoughts ?
  2. True Romance
    True Romance
    Feb 7, 2005
    6,983
    Wolverhampton
    +3,039
    Oh no. Can't see this ending well ;)
    I try and use premium fuel where possible, mainly shell.
  3. un1eash
    un1eash
    Nov 14, 2007
    5,031
    2
    +1,451
    What ever is closest at the time but I do tend to avoid Tesco. It's a diesel after all, not an F1 car.
  4. Dodgy_Geezer
    Dodgy_Geezer
    Mar 22, 2003
    2,679
    London
    +298
    Shell V Power but any premium diesel will do as Shell is stupidly expensive . Otherwise, the standard stuff with a bottle of Wynns is about the same.
  5. Mac User
    Mac User
    Sep 27, 2006
    4,556
    Norfolk
    +309
    Is the addatives any good ? Better then the premium fuel ?
  6. Dodgy_Geezer
    Dodgy_Geezer
    Mar 22, 2003
    2,679
    London
    +298
    The only difference between the regular standard fuel and the premium versions is the additives package that is put in at the depot. Fuel all comes from the same depot, it's the additives which differ between the companies (or in the case of supermarket standard fuel, no additives).
    Regular use of something like Wynns is more of less the same as the premium stuff. For petrol it increases the octane rating, reduces carbon deposits in the engine, reduces knock, etc.
  7. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,193
    Poole
    +11,832
    What difference do additives make?
  8. Dodgy_Geezer
    Dodgy_Geezer
    Mar 22, 2003
    2,679
    London
    +298
    With regular use, cleaner engine, boosts octane rating, fuel ignites more efficiently so suited for high power/high compression engines with a turbo or super charger. Supposed to reduce exhaust emissions too but no idea if they do. Some people swear by the premium stuff, others see no difference than the standard fuel so YMMV.
  9. mjn
    mjn
    May 24, 2001
    24,596
    Herts, England
    +13,420
    Only Shell V-Power for my 335d.
  10. FZR400RRSP
    FZR400RRSP
    Mar 5, 2007
    32,038
    Aberdeen
    +10,374
    Normal diesel, but only proper fuel station versions.
    I won't use supermarket fuel, seen/heard too many bad things about it.
    Like when our fleet IX35 ground to a halt because of a 'gummed up' fuel filter, the first thing the AA man asked was whether the driver used supermarket diesel (which he did).
    Clearly, whatever additive is used to avoid this 'gumming up' is missing from supermarket fuel to cut costs.
  11. qwerty321
    qwerty321
    Mar 20, 2009
    8,067
    +1,583
    Never had any issues with supermarket diesel but definitely found the V Power Diesel to seem to run the engine smoother. That was on a 2.2 Laguna. Since I got my Civic, I've exclusively used V Power diesel bar one fill up when I didn't have time to get to Shell. MPG did take a little dip but it was a traffic filled few hundred miles.
    To be fair I've never tried normal Shell diesel. Currently in a car share I can afford to use the V Power stuff.
  12. FZR400RRSP
    FZR400RRSP
    Mar 5, 2007
    32,038
    Aberdeen
    +10,374
    I haven't used V-power diesel since my A3 sportback 2.0tdi.
    It made it run funny, lots of 'hunting' on a constant throttle, like the ECU was getting confused.
    That was the early days of V-power diesel though (2005-2008).
  13. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,193
    Poole
    +11,832
    I am acreful about supermarkets as well but Sainsburys use BP only whereas the likes of Tesco either buy on the spot market or their garages can be franchises that do what they want.
  14. FZR400RRSP
    FZR400RRSP
    Mar 5, 2007
    32,038
    Aberdeen
    +10,374
    That's interesting.
    So is Sainsbury fuel the same spec as BP forecourt?
    Not having a pop at all, but buying it from BP doesn't necessarily mean they get same spec.
    if it is the same spec, I will consider 'taste the difference' fuel.:)
  15. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,193
    Poole
    +11,832
    I have found Sainsburys to be good on other stuff, never asked about the specifications but of course a given specification can still have wriggle room.
  16. Mac User
    Mac User
    Sep 27, 2006
    4,556
    Norfolk
    +309
    Interesting discussion, So if per litre wasn't an issue Shell or BP or Esso Premium fuel .. What is the best ?
  17. True Romance
    True Romance
    Feb 7, 2005
    6,983
    Wolverhampton
    +3,039
    Don't think you'll go wrong with either of those.
  18. GarethP
    GarethP
    Aug 3, 2005
    641
    Jacksdale, Nottingham
    +477
    I work at BP (not at a petrol station!) they don't get the same additives but they do have some that Tesco etc. Don't...
  19. Epicurus
    Epicurus
    Jan 17, 2006
    3,709
    +696
    The V Power adverts make me laugh: "developed in conjunction with Ferrari." Since when did Ferrari know anything about diesel fuel and engines? Surprised the ASA haven't done anything.
  20. sparkymark75
    sparkymark75
    Jan 6, 2003
    3,235
    Fife
    +747
    I try and stick to BP Ultimate or Shell V-Power. I was under the impression that these both have a higher cetane rating than regular diesel and also burn more efficiently.
  21. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,193
    Poole
    +11,832
    Interesting, I hadn't heard the term before.
  22. tonyrees687
    tonyrees687
    Mar 20, 2006
    2,816
    Iver Heath
    +454
    From what i know is that the crude oil gets refined at the plant and then bio additives are blended with the fuel from anything up to 7 % so who knows what your gonna get from where.
  23. FZR400RRSP
    FZR400RRSP
    Mar 5, 2007
    32,038
    Aberdeen
    +10,374
    Octane isn't a term associated with diesel, as it's used to indicate when a fuel will self-ignite.
    IE, the higher the octane the higher temperature before self ignition.
    Self-ignition is not good for a petrol engine, but it is what you want in a diesel, so the octane rating for diesel is actually very low.
    V-power is allegedly made from better base stock and contains additives to make it burn cleaner.
  24. sparkymark75
    sparkymark75
    Jan 6, 2003
    3,235
    Fife
    +747
    Which is why I referred to the cetane rating, NOT the octane rating ;)
    Shell V-Power - Wikipedia, the free encyclopedia
