Best Denon Amp for....
D
Deleted member 92943
I amoging to be purchasing the new Deno 1920 DVD Player but need an Amp to go with it.
I will be upgrading from my Pioneer VSX-D812 Amp which itself is a really good amp. I would like one which a microphone set-up aswell.
I have a budget of up to £500
Knyght_byte
pray you can get a cheap 3805 when the 3806 comes out in force?..lol
not sure if Denons amps under £500 have the mic setup, they might do, check the denon site for the models....
Will Scarlet
I doubt that even when the 3806 is released you'll see the 3805 drop to £500. It's unlikely retailers will drop the 3805 price below that of the 2805, wouldn't make much sense. Most likely will drop to somewhere between the 2805 and the 3806 price.
golden phoenix
im in the frame to buy a new denon amp, it will either be 2106 or 2805.
seen the 2805 here:
http://www.soundandvisiononline.com/moreinfo/index.asp?product_id=6119
for £499, brand new, which seems to be one of the cheapest at the moment.
or 2106 here:
http://www.petertyson.co.uk/denonavr2106.shtml
for £350.
response of both receivers on this forum is really positive. An both have auto set up mics, as requested. I dont think we will find the 3805 down to £500 new, if you want that model for that price may have to check the classifieds, but probably second hand only!
hope this helps, just cant decide which one for me. If the 2106 does most of what the 2805 can do (as it is a newer model) then this would be the obvious choice because of the £150 saving.
here is a link to the denon website for direct spec comparison:
http://www.denon.co.uk/site/frames_main.php?main=home&MID=1&ver=
As for performance, others with either model can comment on that, best advice, try to demo either or both and make your own mind up!!!! :thumbsup:
Knyght_byte
sorry, my bad, i shoulda made clear i meant getting an ex-demo for £500 in respect to the 3805...lol
most retailers will just stop selling the 3805 after a month or so of the 3806 coming out.......they rarely buy bulk stock of those price amps, so wont have many to shift....
D
The 2106 is the one that i am seriously considering and £350 it is a great deal. I want onw with a mic set-up so i think it will go nicely with my Denon 1920 DVD Plyer
D
Oh and thanks for all of your help guys. I think i am decided
Trending threads
