Best Dell monitor for image editing and artwork
Discussion in 'Computer Components' started by smallangryboy, Feb 5, 2009.
  1. smallangryboy
    smallangryboy
    May 5, 2003
    2,003
    +82
    I'm looking for a good monitor [new or used] to replace my dual setup, a rather mediochre sized Dell 2009W and a Dell E178WFP. My current monitor [Dell E178WFP] tends to have a rather reddish hue despite numerous tweaks to the settings.
    Ideally after another Dell , 19" to 22" doesn't have to be new, I would consider monitors 1 or 2 years old provided they have excellent colour reproduction and display quality.
    I've seen opinions on the Dell SP2208WFP which seem good, any one?
  2. smallangryboy
    smallangryboy
    May 5, 2003
    2,003
    +82
    Or best 20" ~ 22" monitor of any make?
  3. Chanser
    Chanser
    Apr 9, 2004
    1,946
    The Black Hole
    +290
    Ideally you should be looking for at least a S-PVA monitor up to IPS. Lenovo L220X and HP LP2275w uses S-PVA, Lenovo has a higher resolution than HP.
    If you can stretch to a 24" then pick the HP 2475W or NEC 2490WUXi or Hazro monitors, both contain a IPS panel. Dell may have a 22" IPS monitor soon called the 2209WA.
    The Dell you suggested is a TN panel.
