Best deals on Xbox games?
Discussion in 'Xbox Forums' started by Latman, Jun 20, 2003.
  1. Latman
    Latman
    May 18, 2002
    279
    +3
    Where is the best place to buy xbox games? Are they cheaper to buy online or is it best to shop around on the high street. I am after Brute Force and Midtown Madness 3.
  2. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Play.com are usually best for new releases. Amazon currently have 25% off all new releases, but remember to add postage charges (unless you spend over £39 in which case it's free).
    Alternatively, just head down your local indie games shop.
  3. savage
    savage
    go to agree with Willy.
    I buy from Play .
    theres some good deals at HMV at the mo 2 games for 30 on selected games but its a good selection . play also do something similar
    that goes for ps2 and GC as well .
  4. Kevo
    Kevo
    Aug 23, 2001
    5,363
    Manchester
    +146
    3 for 2 offer which Dixons is still running will be hard to be beat by any e-tailer.
  5. dave_b9000
    dave_b9000
    Jan 14, 2003
    164
    19
    try gamestation.co.uk for good prices on used games. free postage over £30 otherwise i think it's only a couple of quid.
  6. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    The 3 for 2 deals aren't for new releases though, are they?
    Personally I'd always go down the indie route anyway. My local place usually does new PS2 games for £32.99, and plus I often get games a few days before release too.
    EDIT - PS2 prices used to illustrate the point. Xbox are usually only a little more.
