Best CRT on a limited Budget
Discussion in 'TVs' started by Hawklord, Dec 26, 2003.
  1. Hawklord
    Hawklord
    Feb 15, 2003
    3,446
    Aldershot, Hampshire
    +267
    My father is looking to get a widescreen tv in the near future. I'm not currently up on what's available at the moment and would appreciate some advice.:D
    He has a limited budget of around £500 and would like the largest screen possible for around that price. He doesn't necessarily require 100hz as he only watches terrestrial t.v and the odd dvd at the moment (via his Tosh sd220) so no digital tuner required at the moment either. He only has two sources at the moment a dvd player and a video recorder with no av amp etc so at least one rgb scart is required.
    No av amp is being used currently so he'll also need a tv that has fairly good sound.
    thanks for any pointers most appreciated.
    :smashin:
