S
studavis
Just looking for reccomendations on the best USB cordless phone out there at the moment. Any help is appreciated!
Monty Burns said:I believe this maybe of use to you.
studavis said:...you can get a cheap and cheerful corded version for like £20. ggod find though - thanks!
rwest said:Hi Monty
I have a Du@lPhone and have had some problems with echo - have you found any problems as I can't find any settings for echo-cancellation.
matthewlee said:This phone does not appear to have an answerphone in its base station. Are there any similar phones due out with a built in answerphone?
Matt
