Best Controller XBOX ? and Scart Issues
Discussion in 'Xbox Forums' started by Warnie, Sep 22, 2003.
  1. Warnie
    Warnie
    Mar 6, 2003
    465
    +25
    The time has come to buy a second controller for the Xbox - I've found a friend to play against !
    Can anyone suggest the best controllers out at the moment and where I can pick one up online ?
    I also want to hook up the Xbox via a scart and have optical out to a 5.1 machine, how can this be achieved if I only have two scarts on the tv and both are required for other machinery? Is there a multi scart option available ? Sorry for the stupid questions!
  2. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    1) Get a controller S. Most people agree they are best.
    2) You need the advanced scart lead, which has an optical out on it.
    3) You need a scart splitter. Argos do one for about a tenner. You'll want the one that does RGB scart - I think it's the one that doesn't have a scart lead attached that you want, which means you'll have to buy another scart-to-scart cable aswell, for connecting the splitter to your TV.
  3. Bassline@ddict
    Bassline@ddict
    Dec 20, 2002
    453
    West Sussex
    +14
    Yeah go with one of the offical microsoft pads.
    Don't buy a third party pad, they may be cheaper but you won't be happy when analogue sticks break and it needs replacing in a few months.
    I'd second the advanced scart lead, big difference from the crappy composite one you get in the box.
    Steve
  4. Messiah
    Messiah
    Apr 22, 2002
    7,529
    +339
    Or get one of the Logitech wireless pads. Absolutely superb but about twice the price of a standard (wired) pad.
  5. Warnie
    Warnie
    Mar 6, 2003
    465
    +25
    Cheers guys, I'll go for the controller s then. I took a look at Argos and couldn't see anything there unless I'm being totally stupid ! Yes RGB is a must with the equipment I have - with the splitter do you have to flick a switch or does it route the output from the xbox, dvd automatically ??
    Any quality lost in the dvd picture by using a scart splitter ?
  6. Bassline@ddict
    Bassline@ddict
    Dec 20, 2002
    453
    West Sussex
    +14
    The switch box is on page 717 of the Autumn/Winter catalogue.
    They call it the "Scart Video Unit"
    Cat no. 534/2361
    £9.75
    It is manual switching though, (hey its £9.75)
  7. Warnie
    Warnie
    Mar 6, 2003
    465
    +25
    Thanks Bassline - seems a good price to me. As long as I can view when I want and record off the scar splitter then that's all I need !
  8. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
