i use config 3 where possible, i just find tapping the jabs easier and doesnt screw up as many times as the stick. for everything else i use the stick (hooks uppercuts and haymakers)
I just started playing this game using config 3 but how the hell do you block?
It says it's one of the right trigger buttons but nothing happens when i press it.
Also is a Haymaker the same as your signature punch? reason i ask is that I have a lot of sucess with it but at the end of the fight when i look at my stats it says Haymakers 0.
My last gripe is how do you throw uppercuts?
I know you can use the direction pad but that is awkward.It would be nice if you could just press a button like you can for hooks, crosses and jabs.
Maybe theres another config with buttons for uppercuts?
Have the same thing where sometimes it says 0 haymakers even though I used them.
You block by holding down the Right Trigger and moving the Right Stick to the area of your body you want to block. It really is worth your time learning to block and parry punches.
