Best connections?!
Discussion in 'Cables & Switches' started by Trick, Jul 23, 2004.
  1. Trick
    Trick
    Jul 23, 2004
    22
    4
    Northamptonshire
    Ive read so many articles over the last few months and im still not sure what is supposed to be the best cabling connections:
    S-Video - I was led to believe this offers the best sound and picture using the 3 cables yellow,red and white
    RGB Scart - High quality scart cable using an RGB scart socket
    Coaxial - Pants.
    Am i missing any?
    Need to make sure my system is set up for the optimal settings.
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    S-video is picture only, it carries no audio.
    Red & White are stereo audio and Yellow is composite video.
    A proper RGB scart cable is picture only as well. You need a fully wired scart cable to do RGB and audio.
    Component video (red, green and blue cables) offers the highest picture quality if available.
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Ignoring any digital feeds and concentrating entirely on video signals and the connectors
    Lowest quality to highest quality is:
    * RF (used for carrying old fashioned television signals).
    * Composite (carried by a single conductor and ground, denoted by a yellow RCA plug)
    * S-Video (splits into chrominance and luminance, denoted by a mini-DIN plug)
    * RGB (splits picture into the three components as used by the tubes within a CRT television, carried over scart leads)
    * Component (splits picture in the three components as stored on DVD, carried over 3 coaxial leads with RCA connections).
    The final 2 are potentially switchable unless you're progressive scan capable equipment in which case component should be superior.
    There's also the RGBVH signal as used on computers but that's rarely relevant for home cinema.
  4. Trick
    Trick
    Jul 23, 2004
    22
    4
    Northamptonshire
    ok and so for audio?
    My dvd outputs:
    S-video out; composite video out; two Scarts (one RGB); six outputs for 5.1-channel decoded sound; stereo audio output; optical/coaxial digital audio outputs; headphone jack; component video outputs
    Is optical the best?
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    It depends what equipment you're connecting it all up to.
    Ideally I think you want to use component video into your display for video, and electrical digital into your AV amplifier for sound.
  6. andy9
    andy9
    is optical digital or co ax digital best??
  7. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    SDI :)
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,355
    Rainham Essex
    +2,441
    Optical or coax are about the same, but coax is slightly better on short lengths and optical better for >10m lengths.
    If useing the DVD player for CD's then you will probably find you get better stereo via a pair of phono leads from the stereo audio outs as well as the above for DVD sound.
    If your screen has component inputs then use component, otherwise RGB scart is the best quality video connection.
    All the above connections should give you a good picture & sound, but this will all be dependent on the quality of the leads used. Don't spend an absolute fortune on leads (unless useing high end gear, and even then its debatable as to how much you should spend), but don't go for really cheap either.
    Mark.
  9. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Playing CD's via my Denon AVC 10Se sounds infinitely better using a digital connection than via the analogue outputs. I am not sure why though
  10. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Your Denon has very high quality DACs in which is probably why it sounds better. You don't mention what player you use though.
    It depends where the digital to analogue conversion is done, ideally it should be done through the best DACs which can be either in the amp or the player.
    DVD players generally have fairly poor audio DACs so will often sound better if they don't perform the conversion but just act as a transport.
  11. probeski
    probeski
    Jul 23, 2004
    96
    I'm from Australia and scart devices have only recently become widely available on our market. Can you explain why Scart RGB is inferior to YPbPr? Apparently DVDs are encoded in YUV but apart from this, assuming the scart RGB and YPbPr cables are high quality, why is one better than the other for progressive material.
  12. MarkE19
    MarkE19
    Aug 10, 2002
    17,355
    Rainham Essex
    +2,441
    Simply because the scart RGB signal is not 'progressive scan', but only interlaced.
    If only playing from an interlaced DVD player then there will be very little, if any difference between RGB & YUV.
    Mark.
  13. probeski
    probeski
    Jul 23, 2004
    96
    Thanks, i thought that was the case i just needed confirmation. I suppose RGBHV is the only RGB type that supports progressive then.
  14. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Correct.
    As an aside, DVD is encoded as component whilst a TV tube is driven by an RGB signal. The reason only component can carry progressive scan is because the processing has to be done to the signal as it was on the DVD rather than as the TV tube needs to receive it.
  15. probeski
    probeski
    Jul 23, 2004
    96
    So what about Scart RGB STB's?
  16. MarkE19
    MarkE19
    Aug 10, 2002
    17,355
    Rainham Essex
    +2,441
    You can only get progressive scan from a DVD player and only via YUV component. Satellite & Cable STB's etc can not output progressive scan.
    Mark.
  17. probeski
    probeski
    Jul 23, 2004
    96
    Thanks for the info. I'm getting a HD STB with either RGBHV (DSUB) or YPrPb output to feed into a plasma. Which one do you think will give the best progressive quality?
  18. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    probably RGBHV depending on the plasma.
  19. probeski
    probeski
    Jul 23, 2004
    96
    I want the Pinoneer 50mxe1, why does it depend on the plasma? I'd imagine that Dsub might be cheaper in price than high quality YPrPb, is this true and can you recommend any good quality RGBH+V connections? Is there a difference in quality when changing to BNCs (into Plasma) or should I keep the cable as the 15 pin Dsub?
  20. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    hmm never compared RGBHV BNC and D-sub, just used which ever was easier. If the Box has D-sub out and plasma has D-sub in (i think it does) use that.
  21. probeski
    probeski
    Jul 23, 2004
    96
    Who makes good quality Dsub and recommendations (i don't mind paying about 40 pounds, cheers.
  22. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Vandamme Red series are good as are bettercables
