best connections from dvd player
Discussion in 'Projectors, Screens & Video Processors' started by scott33b, Aug 13, 2004.
  1. scott33b
    scott33b
    Aug 3, 2004
    68
    Hi. Just got a Barco data 801s. This is my first CRT projector, Having also got an old LCD. I currently have the CRT connected to my DVD player with a s-video cable. Is this the best way to connect? Lots of connection on the back and I'm not quite sure what to do with them.
    I have a sony dvd (dvp-ns700v) and a sony amp (str-db940).
    Any advise appreciated!
  2. GlennR
    GlennR
    Jan 22, 2004
    127
    Nottingham
    +4
    I have sent you a PM
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    component if you have it mate.
  4. rob12770
    rob12770
    Jan 5, 2004
    854
    Edinburgh/Glasgow
    +42
    ditch the dvd player , get an ATI card and run your movies from your PC using windvd...much better.. :)
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Scott without a scaller (line doubler etc) you are probably still best with S-video. converting componet to RGB will get you a small improvement but you might do beter to buy something like a £350 Iscan line doubler.
  6. ufitsy
    ufitsy
    Aug 18, 2004
    3,244
    103
    Midlands
    +341
    I reccomend componant if you have progressive scan out on the dvd, if i'm not mistaken this removes the need for a line doubler, although you may still need one for your other sources. Prog scan players can be had for £80 up.
  7. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Ufitsy
    Scott has a Barco 801s it was designed and built well before component video became available. Converting from Component to RGB is costly (circa £300)
  8. ufitsy
    ufitsy
    Aug 18, 2004
    3,244
    103
    Midlands
    +341
    Apologies Roland, Scott - ignore my last
  9. scott33b
    scott33b
    Aug 3, 2004
    68
    Thanks Roland. I've beeing looking for a line doubler on ebay. Bidded on one last week, but the guy withdrew it early. Hoping to get one somewhere. Don't want to buy it new if poss. The other half will kill me!! She's not best pleased with the size of the Barco I just bought. Need to let her calm down for a few weeks!
  10. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    An Iscan is really small and easy to hide:)
  11. ChopperCharles
    ChopperCharles
    Aug 20, 2004
    34
    Actually, you can get a component to RGB converter on eBay right now for $150. Hell, buy an HK DVD player for about that much. Most HK players have RGB and/or SCART outputs instead of Component Video, as that is much more popular over there. Plus, you get region-free, no macrovision, and usually the ability to skip the FBI warnings (where a bunch of a$$holes are now putting previews and commercials that can't be skipped!).
    Charles.
