Best connection?
Discussion in 'Cables & Switches' started by Les E, Jul 25, 2005.
  1. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    My TV has RGB scart but my DVD player has both RGB Scart and Component out.
    Would I better connecting RGB to RGB scart or Component to RGB Scart?
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Standard RGB and component have a pretty much identical picture. Component has the potential to be better as it can support progressive scan but you need compatible hardware at either end for this to work.
    I think that you're best sticking with RGB scart. :)
  3. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    I thought as much.
    However the player does have progressive and that is one of the options on the Pixel Plus TV (100htz).
    If theres not alot in it though, probably stick to RGB. :smashin:
  4. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    You cannot send componant signals down a scart lead.
    I would suggest Going RGB into your TV.
    Gareth.
