Best Connection??
Discussion in 'Plasma TVs Forum' started by micol, Oct 7, 2004.
  1. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    OK. So i've bought my new Hitachi 42DP5200 plasma and I want to get the best picture and sound possible. I also have a Sky+ box (V2) a Yamada 6600 Divx DVD player, and a Denon 3802 Home Cinema Amp.
    Can anyone offer any advice on the best way to connect all this kit together? The Plasma only has 1 Scart which is a slight problem, but it also has some Component inputs and s-video. Sky+ has RGB scart and s-video and my DVD has RGB scart.
    Should I buy a decent (£30-50 budget) Scart / Scart for Sky+ and a Scart / Component to connect my DVD Player to my plasma? What about the Denon Amp? It has tons of connections and I'm a bit confused. :lease:
  2. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    what is the full list of connectors from the DVD?
  3. BoomBoom
    BoomBoom
    RGB Scart is fine for your Sky+
    either user Component or DVI if you DVD player has it. If you have or get and Xbox or PS2 connect them via component.
    You amp need to connect to you sky and DVD not the screen. Use digital connection where you can...i.e. optical.
    Boom
  4. mray
    mray
    Feb 16, 2004
    2,772
    83
    London
    +234
    If you're using bog standard scart leads, then anything costing over around £15 will give you a big improvement in PQ.
    I got some JVC ribbon scart leads which were about £16-£18 and they made a massive difference.
    Even the Hitachi lead from Argos was decent.
    Component leads imo will give you a pic similar to rgb scart.
    I don't know about these £60 ish leads though, or if they would make that much of a difference compared to spending around £20 ( I've heard they don't).
  5. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    Both DVD and Sky+ will need to connect via RGB scart (I'm pretty sure the Yamada doesn't have component). Remember you need to:
    - activate RGB output in both the DVD and Sky setup menus
    - while your in the Sky+ setup menu set TV type to 16:9, Contrast to Low, Scart Control On and video output to RGB (then press save current settings)
    - use a fully wired (decent quality!) scart lead
    - use the TV scart output of the Sky box (VCR scart has no RGB output)
    - either connect the DVD to the VCR scart of the Sky box to "pass-thru" the signal, or use a switcher such as the JS Technology Master Scart Controller (2-1), BTec Triton (3-1) or BTec Quintro+ (5-1).
  6. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    My DVD player has SCART, S-video, coaxial, optical output. I was thinking I could connect to the Plasma by Scart (from DVD) to Component or DVI (on the Plasma)? Is there such a lead?
    I am currently using the Hitachi scart from Argos (sky+ direct to Plasma). My friend says there is a QED scart for around £50 which is supposed to be fantastic? Also are there special scart leads for plasma screens?
    I have the DVD connected to the Amp via Optical but I can't seem to get sound from the amp for Sky+ using the same method?
    I do have a playstation 2 so how do I connect them via component? Is there a special cable I need to buy?
  7. Stimpy
    Stimpy
    With the optical from the sky+ try switching the sky+ to dolby stereo rather than Dolbly digital (only the movie channels seem to broadcast in DD).
    However you may have the same problem as me with the sky+ box. Optical doesn't work.
    Does your amp do upconversion to component?
    If yes, you can reduce cable clutter by upconverting everything to component, then only have one cable going to the screen. Makes switching easier as well. I.e. just switch the amp channel.
  8. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    Thanks for the advice.
    Liam,
    If I connect my DVD to the VCR scart on Sky+ will I not loose the RGB and will the quality reduce as It's not direct to the Plasma?
    I thought that a RGB Scart with component leads on the other end would be better than a scart switcher as I could then go directly from DVD scart to Plasma Component?
    Stimpy,
    Thanks for the info on Sky+, I'll try what you say. My Amp has loads of stuff on the rear including 3 sets of component points? I have no idea if it upconverts, maybe you can tell from the attached picture?
  9. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    AFAIK that amp upconverts to component
  10. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    OK. If it does upconvert, please can someone let me know how to do it and what cables i will need (sorry for my ignorance!)
  11. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Connect Sky+ to your amp using an s-video lead and phono leads for sound
    Connect you DVD player to your amp using a scart to s-video lead and optical lead for sound
    PS2 to amp using an s-video lead, im guessing you can get on of these, ive not got a PS2, not sure on sound, so cant confirm.
    and then connect your amp to your plasma using a component lead.
  12. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Stimpy
    Optical works fine for me, see page 65 of SKY+ manual.
    Depending on broadcast I get stereo, Dolby Prologic or Dolby 5.1 no problem! :thumbsup:
  13. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,522
    Kent
    +830
    Hi fellas
    - I don't think the 3802 upconverts, only 3803 and onwards do
    - RGB scart is not the same signal as component. A scart to 3 RCA lead is possible but it will not work
    - running the DVD RGB scart to the Sky box is the simplest method, however there will be minor degredation from passing the signal through the Sky box. The JS MSC is best used here.
    - PS2 requires an aftermarket component lead. This is the best option for PS2 but does not work with DVD playback iirc
    Leigh - even if the amp did upconvert I wouldn't want to downgrade my DVD signal to SVHS just for the sake of one cable to the plasma, direct RGB scart appears best in this instance.
  14. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    Cheers for that. I'll give it a try tonight.
    PS. Would it not be better to make use of the plasma's scart and link the Sky+ to it by scart to scart and still use the phono to get the sound through the amp as well?
  15. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Liam : your right i mis-read the model no as 3805 not 3802, my fault
    i forgot that the sky+ box has optical out, so you'd be better off using that :)
  16. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,522
    Kent
    +830
    Yes DVD and Scart should both have direct audio connections to the amp. Both should be optical (if you can get yours working!).
    Then DVD runs RGB scart to Sky+, Sky+ runs RGB scart to Plasma.
    Good Luck!
  17. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    another option is to buy a New DVD Pioneer 575 would be ideal £130 MR...... Well worth it on a plasma....... so then you could go all through the the amp for video and using a JS RGB> Component converter for sky if required. PS2 can also use component..... Personally i would go for DVD and PS2 through Componenet via amp and Sky+ to plasma scart socket, ok so you need to buy a new DVD but it is well worth the extra......
  18. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    Hornydragon,
    Do you know if the Pioneer 575 is a DivX player ?
  19. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,522
    Kent
    +830
    Yeah it does!
  20. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    i typed that without moving my fingers...............
  21. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,522
    Kent
    +830
    :laugh:
