Best connection method
Discussion in 'Plasma TVs Forum' started by Bobby_Dazzler, Aug 20, 2005.
  1. Bobby_Dazzler
    Bobby_Dazzler
    Hi all
    I just need some help with the best way to connect the following
    Sky +
    PW7 with JS RGB TO VGA convertor
    PAnny E55 dvd recorder
    Pioneer vsx c502 amp
    PS2 with scart lead connecter rather than the standard.
    The pioneer has 4 scart sockets on the rear 2 in/outs and 2 scart in only's.
    I just cant figure out how to make proper use of the DVD recorder and also its dvd playing mode !
    I would appriciate any help
    Regards
    Bobby
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    what boards did you get with your panel?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    PS2>AMP
    DVD-R>AMP
    SKY>AMP
    AMP>JS>Panel
    SKY>DVD-R (VCR scart on Sky to AV2 on DVD-R)
    that way you can watch sky, record analogue or play PS2 and record sky etc SKy recording quality will not be the Best but will look much better than VHS
  4. Bobby_Dazzler
    Bobby_Dazzler
    Thanks for your help but its still not having it !
    I can get a picture if i go from the sky box staight to the rgb convertor but for some odd reason if i go through the pio c502 as you said i get no picture.
    so far i have only connected the sky box to the amp and the convertor to the amp.
    Weird!
  5. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    does the pio pass thru RGB on every scart connection?
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    No it does not!! You need to make the TV/DVR scart the out to VGA box, the VCR one does not output RGB. It will input it but not output. Yes, I have been there before, scratched head for some time....
