Best Connection for Xbox
Discussion in 'Xbox Forums' started by mstodge, Jun 18, 2004.
  1. mstodge
    mstodge
    May 6, 2004
    264
    Birmingham
    +5
    I want to connect my xbox with the best connection to my plasma tv.
    I've got the RGB scart already and was wondring if it is better to connect via the Component. also still need to connect the audio to my amp via optical cable.
    Mark.
  2. zAndy1
    zAndy1
    Nov 26, 2002
    22,220
    2
    5
    163
    +8,664
    Yep component definitely. What plasma is it? Best method is to get it modded, change to NTSC and use 720p or 1080i when it's available. Even 480p is better than nothing though!
    Andy
  3. mstodge
    mstodge
    May 6, 2004
    264
    Birmingham
    +5
    hi cheers,
    It's The Pioneer 434HDE.
    Whats the best way to connect via component. Also whats the best way to get it modded in UK?
  4. zAndy1
    zAndy1
    Nov 26, 2002
    22,220
    2
    5
    163
    +8,664
    well, you need a microsoft hidef av pack, then just connect it using a component video cable. To get it modded check out www.premodded.com although I must warn you there's no guarantee x-box live will continue to work indefinitely if you mod your console. It does have it's advantages though!
    Andy
  5. mstodge
    mstodge
    May 6, 2004
    264
    Birmingham
    +5
    Thanks for the link zANDY1 will probably get it done there. Not bothered about Xbox live yet until FIFA 2005 comes out.
    Mark.
