Best connection for XBOX to RPTV scart
Discussion in 'Xbox Forums' started by ajbm325ic, May 28, 2004.
  1. ajbm325ic
    ajbm325ic
    I require advice/opinions on the best connection for my setup.
    UK XBOX with Executor 2 fitted. Sony KP44PX2 RPTV with RGB Scart/no component connections. Yamaha DSP Amp with optical in. Not only the best connections but the best value manufacturer for the money. Hurry chaps as i would like to get this setup for the weekend. What is the hi def kit and will it be suitable for my setup? Please list where i can get any suggestive cabling solution.
    Thanks,
    Andy.
  2. Pooon
    Pooon
    Dec 26, 2002
    7,344
    Canterbury, Kent
    +935
    Get yourself the official microsoft advanced scart lead. that will give a RGB connection into your TV, and it also has an optical out jack so you can connect it to your amp, i don't think that an optical cable is supplied thou. Highstreet stores like Game and Gamestation stock them, as do many online stores, www.play.com i think do it.
    The high-def pack you mention will not be suitable as it is designed to be used for TV's that have component connections, which you say your TV does not have.
