Does anyone actually own one of these beasts?
I hear that using the HDMI interface card you cannot run 24fps native? But you can using DVI (or is it VGA)?
Is this correct?
What would be the best way of connecting it from the amp, assuming that a scalar is not in the equation (yet). (yes i know i should get one, but i dont have enough for both right now, so i figured i would do it one bit at a time)
I will be running Sky HD, Xbox 360, Wii and HD DVD (through xbox360).
So 1 HDMI into the amp and 2 component. The amp can output all of these through the HDMI and obviously i can convert hdmi to DVI with little fuss.
Many thanks in advance for your advice.
Is this correct?
