Best connection for Sky+ to LCD
Discussion in 'Sky Digital TV Forum' started by Deano70, Oct 25, 2005.
  1. Deano70
    Deano70
    Aug 11, 2004
    357
    Hi All what's the best way to connect my Sky+ box to my LG LCD is it scart to scart or is scart (sky+box) to component the best connection.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    RGB scart, no SKY hardware outputs component so you would have to add a convertor or run it through an amp. If you already have that option then try both and see which your eyes prefer:)
  3. Deano70
    Deano70
    Aug 11, 2004
    357
    Cheers I'll stick to my SCART to SCART.
  4. Astaroth
    Astaroth
    Jun 22, 2004
    3,708
    London
    +898
    It depends on your system - most will be best with RGB Scart but there are some sets which will actually look best with s.video. My set up is s.video to my AV amp which converts it to component however my TV is well known for not handling RGB to a great standard.
