Best Connection for DVD to Amp ?
Spy
Dear all,
Apologies if this is covered elsewhere, I searched but as you will appreciate, too many results came up !
My Amp and DVD have both types of digital connection for connecting the two.
Which one would offer the best sound quality - coaxial or digital ?
Can you also recommend a good cable for the better connection.
KraGorn
With high-quality cable coax is better for short/medium lengths .. you can get some exceptionally good cable using Mark Grant's cables available in the 'powerbuy forum'.
Z
Zoidy
so ive been led to believe.. coax digital for movie sound, stereo phono's for cd playback
Ian J
Not necessarily so as the sound from CD's via the digital connection on my setup is far superior to the analogue outputs
Spy
Thanks Guys.
Any make/model of digital coax you recommend based on experience ?
Not too pricey mind you, say up to £40ish
Spy
Thanks Ian.
I read the thread in the Power Buy after posting - I'm convinced on just the value for money basis.
Will have change left for the Sub cable
I am thinking of getting the KEF eggs and sub.
What type of connections would I need on the sub cable to connect a Denon 3803 to the KEF Sub - if I need one anyway.
Obviously unsure as I haven't bought them yet, but would like to get all the accessories in advance so I can set it all up straight away once the speakers come :D
Spy
Thanks Ian - I assume it is RCA connections on both ends ?
