best conections for tosh 32wlt66???? component cable recommendations!!!
Discussion in 'Cables & Switches' started by djt111, Dec 19, 2006.
  1. djt111
    djt111
    Nov 29, 2006
    1,464
    63
    +203
    have got a prog scan dvd player, think the best way to connect this will be via component?
    who makes the best budget cable, ixos, qed?? seen some on ebay for around £20? are they any good?
    only need them to be 1m!
    or will a scart to component work?
    also whats the best audio budget conections 2 rca to 2 rca?
    cheers if you can help :thumbsup:
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,480
    2
    +1,367
    What Make and model is your DVD player and what length cable do you need?
  3. djt111
    djt111
    Nov 29, 2006
    1,464
    63
    +203
    not sure what make and model the dvd is was cheap only about £30ish from a supermarket (will check later)
    only need 1m cables may be able to get away with 0.5 as the dvd is under the TV?
  4. Andy98765
    Andy98765
    Feb 15, 2006
    10,480
    2
    +1,367
  5. djt111
    djt111
    Nov 29, 2006
    1,464
    63
    +203
    cheers m8
    its an akura adv147as
