Best component DVD player?
Discussion in 'Plasma TVs' started by Claus, Jun 18, 2004.
  1. Claus
    Claus
    What would you recommed as the best DVD player with a progressive analogue component output?
    I need a good analogue DVD player to connect to my Panny 50" Viera, since it doesn't take DVI/HDMI in.
    The Arcam DV79 or the DV88 or maybe the Marantz 8400?
    Claus
  2. YS-YS
    YS-YS
    take a look at the denon A11
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    Take a look at the high-end players from Denon, Arcam and Marantz for quality YUV out...
  4. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    I've just got an Arcam DV79 which I've got connected via component to a Hitachi 42PD3000 and the picture quality is superb - it's a vast improvement over my previous player, a Yamaha S540
    John
  5. spook
    spook
    May 18, 2004
    157
    Hi, I just got a panny DRM-E55 DVD player/recorder along with my new PWD6, seems to be an excellent match, looks stunning using component connection in prog scan.
    spook
