best compact(ish) surround speakers for wall mounting
Discussion in 'Home Cinema Speakers' started by kev777, Aug 1, 2005.
  1. kev777
    kev777
    Jun 27, 2005
    144
    Hi All,
    as the title says, but given I'm a bit of a newbie afraid I need some advice. Ideally I want a 6/7.1 system and prepared to spend upto £1000 or so.
    Ideas so far:
    Infinity Oreus
    KEF KHT 5005
    As you can guess I'm looking for something small (ish) and unobtrusive but with a big sound and looking to pair it with a denon (or maybe Pio) receiver.
    Any recommendations on the above or is there anything else??
    Many thanks,
    Kev.
  2. recruit
    recruit
    Hello Kev,
    I would also look at the K Series speakers from M&K which are nice and compact and sound very good.
    www.mksound.com/Kseries1.php
    Regards
    John
  3. kev777
    kev777
    Jun 27, 2005
    144
    thanks. I had a look and although this sounds pretty shallow to an audiophile I do prefer the look of the 5005s, plus the M&Ks seem to be a little more.
    I guess the only other question is whether to go for a 5.1, 6.1 or 7.1 setup??(by the way, the room the system will be in is about 13 x 16 feet). Any suggestions very welcome...
    Thanks,
    Kev.
