best coaxial cable
Discussion in 'Satellite TV, Sky TV & FreeSat' started by craig7, Aug 19, 2013.
  1. craig7
    craig7
    Dec 6, 2010
    32
    folks what would you recommend is the best coaxial cable to buy? one which carries most voltage / power / strongest signal etc...
    thanks
  2. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,169
  3. craig7
    craig7
    Dec 6, 2010
    32
    thanks, it would be 15 meters
  4. Trollslayer
    Trollslayer
    Feb 11, 2007
    24,541
    Poole
    +9,772
    15 metres isn't a problem with decent cable.
  5. bobbyg85
    bobbyg85
    Aug 14, 2013
    3
    Again depends what it's purpose is, if its for sky tv you're best with ct63 shotgun cable, or as the other guy days wf100 or ct100. Virgin use RG6, you generally get about 1db loss for every 10m of cable you use
  6. excollier
    excollier
    Sep 9, 2011
    170
    Letterkenny (ex-pat from Staffs.)
    +10
    I always, without exception, fit Webro WF100 or Triax TX100. It saves any future problems. I have used it up to 50m without any problems, and I'm sure it would go a little further than that without having to step up to WF125 or similar.
  7. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,648
    Cheshire
    +1,078
    Webro has the lower loss as it's near pure copper Triax is much tougher as it's copper has an additive but loses c. 6% which is a good trade off in some situations. The bigger the number HH100 HH125 HH165 HH233 = bigger area / dia. = the lower the loss and better shielding but it gets expensive
  8. craig7
    craig7
    Dec 6, 2010
    32
    okay folks, thanks for the reply. the problem i have is my sky f3 box is only getting H polarity channels with the thinner type satellite cable, where as with the thicker sat cable i am getting all the channels, i need to purchase the thicker cable just not sure the name of that type of cable? #
    Thanks.
  9. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,169
    Is this the same cable that got only V polarity but works ok with a Sky box???
  10. logiciel
    logiciel
    Feb 2, 2008
    53,104
    UK
    +5,759
  11. craig7
    craig7
    Dec 6, 2010
    32
    hi, both types of cable work fine and on a sky plus hd box (get all channels), however on a sky f3 box with the thicker cable i get all channels working but with the thinner cable i only get H polarity channels, V polarity channels say no signal. I need more of this thicker type cable.
    thanks
  12. rolyateel
    rolyateel
    Aug 21, 2013
    5
    Any CAI Approved/Benchmarked coaxial is suitable
    Full list here:
    CAI Benchmarked Cable
    WF100 is not the be-all and end-all of coax, and is made in China just like all the others
  13. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    For a "universal LNB" the polarisation switching is achieved by changing the applied voltage - either 13v or 18v (nominally). The cable has no discernible effect on this voltage unless the cable is extremely long, in which case you'll lose HORIZONTAL (= 18v) polarised channels. A bad connection (corroded) can have the same effect and is far more likely.
    To lose VERTICALLY polarised channels, you'd need a situation where the voltage was too high. This can happen with some receivers where the LNB voltage (sometimes labelled "power") is set to "high" in the menu. It can also happen with some LNBs (= faulty*). Rarely, it can happen where a receiver is supplying fractionally too high a voltage - usually because the LNB is very efficient and drawing less current than most.
    *Faulty in the sense that it's taking all its power from another receiver and none from the output where the "fault" is present.
    This type of fault can only be diagnosed by measuring the voltage under load. I used to carry a "T" F connector that let me "tap in" to measure it. (This doesn't do the signal any good so it can't be left in circuit.)
