Best choice with HD200x?
mepsipax
Hi I will be purchasing a projector screen to go with my new Optoma HD200x, and would appreciate some advice.
The throw distance is 11'6", which according to projector central's calculator, should allow a 16:9 screen of between 98" to 106".
I would prefer to get the largest screen possible.
I think I can achieve the maximum - 106" by using the full zoom on the projector, but is this advisable?
I have been offered a good deal on a 106" screen as well, which further adds to my preferring to get that size, but if you guys advise otherwise...
Also will a matte white screen be ok, my room has very dark curtains, but cream walls and ceiling, so I will consider a grey screen if it will look better?
Thanks in advance
kbfern
I use the max zoom myself to get the largest image possible (just over 100" 2.35:1) and see no detrimental effect so I would not worry.I would recommend a grey screen with your room conditions.
The problem is grey screens are not as readily available as white so depending on the price & quality of the screen you have been offered it may be worth going for that one.
There is a guy on e-bay that sells a 100" grey electric for around £100 and a few off the forum have bought them but don't expect a high quality screen at that price.
mepsipax
Hi Thanks for your advice, I will look into purchasing a grey screen if possible, though if I can't find a suitable one, I will get the matte white screen on offer, and look into making the room more suitable.
I have been saying for ages I need to re-decorate, so this may be the incentive I need!
Thanks again
