unique
i'm looking for a laptop case for 17" widescreen dell vostro 1700. i quite fancy getting a backpack type. i saw some swissgear ones that were about £36 which i thought was a bit pricey, but it's supposed to be good quality and it looks spacious enough to carry plenty more stuff, but comments suggest my laptop might not fit. i don't want to spend that much if it's not going to fit right, i'd rather just use a cheap case
i've looked at play, amazon, misco, ebuyer, dixons, comet. is there anywhere else good (pricing and choice wise)?
alternatively i could get a normal backpack from tk maxx or a sports shop, which will probably do the same job (just less protection). as i wouldn't carry it about a lot, i don't want to buy an expensive case for infrequent use, although i'm always on the lookout for a bargain, so if someone offered me a £100 top of the range backpack for £50 then i'd probably buy it.
