Best / cheapest bracket for Pioneer PDP434
Discussion in 'Home Cinema Buying & Building' started by yasa22, Dec 12, 2003.
  1. yasa22
    yasa22
    Jan 14, 2003
    64
    Uk
    Should be getting mine next week, but I need to get hold of a good / cheap tilting bracket for it.
    I want to mount as close to the wall as possible or maybe even remove the plasterboard and mount bracket onto breezeblock behind.
    Any thoughts / links / ideas appreciated.
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    Check out the power buys section if you are happy with a non-tilting option for £130.
    Otherwise contact av-sales (who are doing the power buy) as they have a good range or universal and unicol brackets for a good price...
    JJ
