Best centre speaker cable
Discussion in 'Home Cinema Speakers' started by gan*, Nov 17, 2003.
  1. gan*
    gan*
    Oct 18, 2003
    77
    I have a mission m3 setup, my floorstanders use QED silver anniversary bi wire, and there was a lot of difference to the bell wire i first used. My centre and back speakers need new wiring.
    Any reccomendations? I could never afford to put the QED for the back ones, but would it be good for the centre speaker?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I would use Silver Anniversary for the centre speaker to match the front mains but something like Ixos 607 for the rears. This is flat cable with a self adhesive strip down one side and is excellent for under the carpet or along skirting boards
  3. gan*
    gan*
    Oct 18, 2003
    77
    Cheers Ian, bought the silver for centre. Ixos 607, any website that I could get that from?
  4. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    hifibitz have it at £1.79 per metre here. I use the Silver Anniversary / Ixos 607 combination myself.
  5. gan*
    gan*
    Oct 18, 2003
    77
    Thanks mate, I think i'll order some of that.
  6. Stellavision
    Stellavision
    Apr 7, 2003
    2,287
    Southsea, UK
    +96
    I use Silver Aniversary Bi-wire on my fronts but bog standard heavy duty Maplin speaker cable on my centre.
    Have wondered whether I should be bi-wiring my centre with the same as the fronts. Do you recon it makes a big difference ?
  7. gan*
    gan*
    Oct 18, 2003
    77
    I wouldnt know, but I can let you know tonight though. But I do know that when I changed my fronts from normal wire, to Silver ann bi-wire, it made a lot of diff.
