Best center speaker
Discussion in 'Home Cinema Speakers' started by linkster, Nov 28, 2004.
  1. linkster
    linkster
    Nov 24, 2004
    681
    +8
    I have a fairly small setup (Panasonic receiver, B&W shelf speakers as left and right, Toshiba came-with-the-telly speakers for rear) and want to replace my center which is a crappy old Kenwood.
    Had always had it in mind to buy a B&W as I like the shelf ones I have, looking to spend £170 tops. Can anyone convince me of a better option?
    Thanks loads
  2. recruit
    recruit
    What B&W speakers do you have for the left & right?
    John
  3. linkster
    linkster
    Nov 24, 2004
    681
    +8
    Dm-303
  4. recruit
    recruit
  5. linkster
    linkster
    Nov 24, 2004
    681
    +8
    Cool :) It's what I'd always fancied anyway.
    If I can bother you for some other advice, is it worth me upgrading my cables too, the ones I have came with an old hi fi system, if so what would you recommend?
  6. recruit
    recruit
  7. linkster
    linkster
    Nov 24, 2004
    681
    +8
