best CD-RW/DVD combo for HCPC
Discussion in 'Desktop & Laptop Computers Forum' started by Richard Harnwell, Jul 1, 2002.
  1. Richard Harnwell
    Richard Harnwell
    Sep 17, 2000
    315
    Colchester, Essex
    +4
    (part 2 in an occasional series of ideas for the new DIGN case based HCPC)
    As the DIGN case has only 1 5.25" slot, a combo drive seems like the best way of using it (as I cant afford a DVD rewriter...).
    I would think the requirements are:
    Must have
    Region Free/region free firmware available
    Quiet for DVD playback
    Nice to have
    Black front
    Buffer under-run prevention
    Slot loading (I think this would look better behind the door)
    Cheap :)
    Any ideas what's around at the moment that comes closest to these requirements?
  2. Desmo
    Desmo
    Jan 4, 2001
    14,452
    Braintree, Essex.
    +6,492
    I asked the same question in another thread a little while ago.
    Only one mentioned was plextor. I think I'm going to wait until the case is all sorted and then worry about it at a later date.
