Best CD player to partner Pio AX5i
Discussion in 'AV Receivers & Amplifiers' started by Matthew J Taylo, Dec 20, 2004.
  1. Matthew J Taylo
    Matthew J Taylo
    Jan 3, 2003
    164
    19
    Adelaide
    I've recently purchased a set of Monitor Audio S6's & have been running them in over the last week (I still have another 25 hrs to go!!), after a little messing about with positioning etc.. I've decided to use both bungs in the rear ports.
    Whilst I do conceed that I have a small room for these speakers but I've noticed that I'm "missing" some of the mid-range. I have bags of bass (possibly too much) & lot's of treble but I'm struggling to hear the midrange.
    The system I'm using consists of a Pioneer Ax5i AV amp (set to direct) & a Denon RDC-02 cd player (connnnected by Merlin Chopin interconnect).
    I've read on other posts that the Pioneer amp can be a little bright so I was wondering what other CD players I could look at as when I play the same tracks on my 5 yr old DR600 Marantz cd-r it does sound a little better, I think?
    I do listen to some quite challenging music, i.e. Muse
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,741
    London
    +1,075
    What is your price range Matthew?
  3. Matthew J Taylo
    Matthew J Taylo
    Jan 3, 2003
    164
    19
    Adelaide
    Apologies, should of added this.
    Anything up to £500 & I don't mind second hand kit if worth the investment & I will notice a sig diff Vs the Rotel
    matt
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,741
    London
    +1,075
    For £500 I would have thought that there's not much out there brand new that would be significantly better than the Rotel. Hwow about the Arcam CD73T?
    If not, then check the classifieds - you should get more bang for your buck!
  5. ahin4114
    ahin4114
    Nov 1, 2004
    1,066
    Reading
    +48
    It may be worth mentioning that lots of people (me included) find the S6's very bassy. The S8's despite the extra bass driver actually are less bassy, much more controlled. So you are not alone in having to bung your 6's.
    As far as the CD player is concerned I can recommend the CD73, very good player, and upgradable later if you wish. If you're willing to go second hand then you may be able to pick up a Roksan Kandy within your budget, more detailed than the Arcam but not to everybody's taste styling wise.
  6. Matthew J Taylo
    Matthew J Taylo
    Jan 3, 2003
    164
    19
    Adelaide
    Thanks guys,
    I did demo the Marantz 7300 & the Arcam 73T with a Pio Ax5i + the Kef Eggs (my old speakers) & the Rotel suited the kefs better IMO.
    Now that I have quite bass heavy speakers I'm not sure the rotel is the best parnter, especially considering my marantz dr6000 cr-r sound better, I think.
    I'm going to leave it to after Xmas & see if anything comes up in the sales etc..
    Matt
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,741
    London
    +1,075
    Check out Sevenoaks, who are doing an accessories offer on Arcam, Rotel & Cyrus products in their sale!
  8. Matthew J Taylo
    Matthew J Taylo
    Jan 3, 2003
    164
    19
    Adelaide
    thanks Tejstar - will do
    Matt
