Best CD player for £1,000
Discussion in 'Hi-Fi Stereo Systems & Separates' started by sticker, Jul 22, 2003.
  1. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Looking to replace my Marantz CD6000KI CD player. I have around £1,000 to spend on one and don't mind second hand.
    Currently thinking of MF 3.2, Arcam Cd23t, Meridian??, Marantz ?? any other I should be thinking of? One constraint is that it must have a matching amp of equal quality (WAF)
    John
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,966
    2
    +3,338
    Wouldn't hesitate to recommend the Audio Note DAC/Transport and one-box designs. There are dozens of amp combinations to match up with as well (up to a healthy $250,000). It isn't very attractive stuff but I think it sounds brilliant. Build quality is top notch as well. The CD2 that I've got has been replaced by the 2.1 but the principal is the same- Sony transport coupled to 24 bit DAC's with a valve (!) output stage.
    You could always give Naim a listen. My Dad wouldn't listen to anything else. I would rather listen to anything else. Ed
  3. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    How about the Tag Mclaren DAC20 i'm seling in the classifieds coupled with a transport such a Teac VRDS 25 ? or hunt for the matching Tag transport
  4. marck
    marck
    Jul 10, 2002
    600
    London
    Go and try the Copland CDA822 - it is an amazing cd player....
  5. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Any of the CD players you mentioned would be good choices.....also worth a look is the CD player listings on ebay.....sometimes there are very good machines to be had there at good prices...and a few Meridians on there at present.
  6. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Thanks guys for the suggestions.
    Alexs2, do you know what Meridians I should be looking at, I heard one in a dealers a few months ago (don't know what model was) and it sounded really good, although I suppose it should have done, it was connected to a £4k Chord amp!!!
  7. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Basically,any of the newer models,preferably the newer the better that still fits into your price band....something like the 507 should be ideal...also be careful of getting caught up in bidding on an item....set yourself a maximum,and dont go over it.
  8. ncpl
    ncpl
    Jan 21, 2003
    348
    Surrey
  9. Spligsey
    Spligsey
    Jan 16, 2003
    2,097
    UK
    +148
    @ £1480, a Meridian 588 would be a great purchase.
    I've heard it numerous times and there's no doubt it has great ability.
    If i had some spare dosh, i'd saw his arm off for that.
    Adzman.
  10. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Spligsey, suprised to see you recomending Meridian Mate :devil:
    Seriously what amp in the meridian range would go with this?
  11. Spligsey
    Spligsey
    Jan 16, 2003
    2,097
    UK
    +148
    sticker, i get boring after a while dont i!:D
    Depends on what you're after.
    Preamp + power amp, integrated amp, or just power amp?
    The big Meridian power amps are not particularly good WAF!!!!!
    My experience of Meridians 2 channel pre-amps/integrated is seriously limited.
    Adzman
  12. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Good to see the alternatives mate :smashin:
    Think I'll have to be looking at integrated, less boxes = higher WAF, if you get my drift.
    Meridian really appeals to me for 2 channel (although I did say multi channel I perferred Arcam/Tag, sorry Spligsey!) the Cd I heard really did sound good, will have to find out what it was tomorrow.
  13. Spligsey
    Spligsey
    Jan 16, 2003
    2,097
    UK
    +148
    You do know your Doctor can look @ your ears mate!!!!:D
    Meridian integrated seems to point @ the 551 unit.
    55w @ 8 ohms or 80w @ 4 ohms.
    I haven't heard this unit, so i cannot give an opinion on it.
    It'll cost you about £900 new, or perhaps about £500-£550 ex-dem.
    I take it you listen to 2 channel stuff seperate from your AV stuff, although you have a cool Arcam front end there.
    Adzman.
  14. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    :laugh: :laugh: :laugh:
    Thanks for your help mate, just looking on Audiophilecandy, seen a 506 and a 502/501, doing some more investigation.
    Listen to 2 channel via the DV27/AV8 a lot, its very good, much better than my Marantz Cd/Marantz 6010Ki combo, but I want a seperate HiFi so that I can escape the wife's Emmerdale/Corrie/Eastenders/family affiars.........:laugh:
  15. Spligsey
    Spligsey
    Jan 16, 2003
    2,097
    UK
    +148
    I dunno mate, you can't whack a bit of Pat Butcher in DPLII:laugh:
    One thing's for sure, for about 1K you'll be able to get a very nice CD player, as there are some cracking buys at that price.
    The ARCAM CD23T is another good player.
    I think the Linn Genki is a nice player too.
    I recently (very recently) heard a Marantz CD17 MKII KI. I thought it sounded pretty cool (hooked up to some KEF XQ speakers)
    One of the best (yawn time:eek: :eek: ) CD setups i've heard recently has to be a Meridian 588, hooked up to a pre-power combo.
    The power was the mighty Meridian 559 2 channel unit, which was pumped into B&W Signature 805's.
    (Alas, i didn't find out the preamp being used:rolleyes: )
    I played some of my type of music (D-Train) through the system & it was utterly fantastic. Real Groove factor & fantastic clarity.
    Hearing that made me realise that there is life left in the old dog named 'CD' for a while yet.
    Let me know what you end up with mate.
    Adz..
  16. Tee Tee
    Tee Tee
    Apr 3, 2002
    125
    Shropshire
    +3
    Thought about Cyrus?
    CD Player: CD7Q with PSX-R power supply (may want to consider new CD 8)
    Amp: Cyrus 8 with PSX-R
    Both of the above are in your price range, sound absolutely stunning and have high WAF to boot!
  17. mick23
    mick23
    Mar 20, 2002
    801
    uk
    sticker possibly something else to consider not heard any of the above cd players but the njoe-tjoebe cd player has valve output stage starts at £430 is upgradable ,you can add 24bit 192 upsampler which then makes the total cost about £1000.
  18. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    Linn Genki CD with matching Linn Kollector & LK85 (or LK 145) amp. Nice!
  19. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    Would that be "You're The One For Me", original Shep Pettibone 12" remix?
    Sticker
    Get yourself a Meridian 200 or 602 transport with a decent outboard DAC, it'll save you a packet, they're the amongst the best transports ever made.
  20. Spligsey
    Spligsey
    Jan 16, 2003
    2,097
    UK
    +148
    Afternoon Gary.
    Not quite mate, it was the "Labour Of Love" remix of "You're the one for me", with additional production by the master keyboard man: Paul Hardcastle.
    It's a seriously groovy tune and really shone on that system i previously stated.
    sticker: good advice from GaryG:smashin:
    aDZ...
  21. NicolasB
    NicolasB
    Oct 3, 2002
    6,070
    Emily's Shop
    +669
    Did it sound organic?
  22. Spligsey
    Spligsey
    Jan 16, 2003
    2,097
    UK
    +148
    :D :D
    Nah, it sounded the b0ll0k$:cool:
    Adz....
    PS.....Gary, Inbox >>>
  23. NicolasB
    NicolasB
    Oct 3, 2002
    6,070
    Emily's Shop
    +669
    How frequently are b******s not organic?
