Best CD player and speakers for NAD C370?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by innercry, Mar 25, 2006.
  1. innercry
    innercry
    May 10, 2004
    67
    Midlands
    I used to use an Arcam CD72T and mission M74s with my NAD C370 via cable talk monitor audio 3 phono leads and QED silver ann. biwire speaker cable, but they now sit with my rotels. So Im looking for a new CD player and stand mount speakers to compliment the C370 when listening to Metal of all variaties! Does anybody have any suggestons, as I wasnt totally satisfied with the previous combination as it did seem to be as exciting as I like it to be?
  2. Mentally
    Mentally
    What is the budget?
    Anyway, I recommend going for a CDP from NAD too for the sound match. recommended speaker brands: B&W, Triangle, Jm Lab, and Jamo.
  3. innercry
    innercry
    May 10, 2004
    67
    Midlands
    The budget would be around a grand for both speakers and CD player, however I am may go back to using my Arcam and lash out on a new CD player to go with my Rotels.
    Im looking for something that has clarity but also has drive as I listen to a lot of Metal with a smattering of classical.
