geordie_blerk
Hi, just got my hi-def compatible screen and I'm going to build a HTPC to get the best out of it but I'm not sure which is the best video capture card for the kit I have.
The main video sources are my Sky box which I'm currently using RGB Scart and XBox, using RGB Scart or component.
What cards would you recommend? I've been looking at the Hauppage PVR 150/250/500 series but wasn't sure how I can best connect Sky and Xbox at the same time. Perhaps get two cards for each input?
I intend to use a media desktop (haven't decided which one yet - MCE2005 or Snapstream?) and get the output of the Sky box and XBox into the PC then rescale it and output it via DVI to the DVI connection on my screen.
I also want PVR capabilties from the card for the Sky input even when viewing the XBox.
The cost isn't an issue so what would you go for?
