ScreechOwl
Established Member
I need to hang the Panasonic 55CX802b on the wall but do so in such a way that I can swivel it out of the way when I use the projector.
The set will be mounted in a corner so in normal use I want it at 45 degrees across the corner and at an appropriate height (to be decided). When the projector is in use I want the TV to be moved back out of the way to avoid impeding the projector screen.
Having read a number of posts on here and done a bit of digging it is clear that some sort of cantilever is needed. What are the best cantilevers, and how best to secure them to the wall - just doesn't seem enough to use a few 8mm plastic plugs and 6mm screws - oh and I want to get it before the 24th ....
My viewing distance is 4.27 metres (I know borderline for a 55" but I really didn't want a bigger set), the mount wall is breeze block (or brick) and plaster, re decorating is not an option so exploration not possible, I have 92cm from the corner to a window. I don't care if the TV impinges on the window a little in normal use or totally when the projector is in use. The TV weight is 22kg, overall width is 124cm, height is 72cm, the bracket mounting holes are on 40cm centres.
By my reckoning the height from floor to the bottom of the TV should be 66cm, that would put the viewing line 1/3 of the way up the screen (with a 90cm viewing / eye height). I've looked at the Vogel's WALL 2345 and it looks as though it should work.
Any and all advice / abuse welcome
