You are absolutely right when it comes to phone cameras. Such is the quallity of phone cameras these days, they would most certainly do a adequate job. The issue is - as you mentioned - not looking like a complete fool trotting around millions of pounds worth of property and taking photos on my phone.
Would you be able to link some potential camera and lens options? Would very much appreciate it,
You have the choice between cameras with optical viewfinders or the ones with electronic viewfinders (EVF). With the latter try to get the highest resolution EVF you can. The EVFs in the Canon M50 and Olympus EM10 MKII are 2.36MP vs just half that res in the Sony A6000,
Canon 4000D with 18-55mm lens (28.2 to 88mm equivalent) £270 plus EF-S 10-18mm lens (16mm to 28.8mm equivalent £199
Total: £469. Absolute bottom of the range, no frills but is reviewed as taking decent photos. Poor low res rear LCD. The EF-S 10-18mm lens gets good reviews and has image stabilisation.
Canon EOS 4000D review: Is this the best budget DSLR yet?
Canon EF-S 10-18mm f/4.5-5.6 IS STM Review
Nikon D3500 with 18-55 VR lens £389 (27mm to 82mm equivalent) plus Nikon
AF-P 10-20mm f4.5-5.6 G DX VR lens (15 to 30mm equivalent) £218
Total £607.
Nikon D3500 review
Nikon D3500 Review | Photography Blog
Nikon 10-20mm f/4.5-5.6G VR AF-P DX Nikkor Review
Canon 200D body £458 plus the EF-S 10-18mm lens £199.
Total £657 or £508 with 18-55mm lens plus again the 10-18mm lens
Total £707.
Canon EOS Rebel SL2 / EOS 200D Review
Canon EF-S 10-18mm f/4.5-5.6 IS STM Lens Review
Sony A6000 (£395) with Samyang 12mm F2 (£299)
Total £700. Equivalent to 18mm but manual focus and manual aperature. Although this may make it much more difficult to use if you are not used to older manual film cameras. However the A6000 has good focus peaking although its electronic viewfinder is not the best and is low resolution compared to the Canon M50.
Or A6000 with the kit 16-50mm lens (24 - 75mm equivalent) £459 plus the samyang 12mm
Total: £758
Sony a6000 Review
Gear Review: Rokinon (Samyang) 12mm f/2.0 NCS CS Wide Angle Lens - Trail to Peak
Canon EOS M50 body £469 with EF-M 11-22mm lens (Equivalent to 17.6mm to 35.2mm) £283.
Total £752
Again this Canon wide angle lens gets good reviews.
Canon EOS M50 Review
Canon EF-M 11-22mm f/4-5.6 IS STM Lens Review
Olympus EM10 MkII body £379 with 9-18mm lens (equivalent to 18-36mm) £405.
Total £784
Bang for the Buck: Olympus OM-D E-M10 II Review
If you want to buy new the Nikon D3500 seems closest to your stated £600 budget or the Canon options using the same well reviewed (for the price) EF-S 10-18mm zoom lens. The M50 with it's wide angle zoom is another option at higher cost. From the reviews the two Canon wide angle lenses perform better than the Nikon one.
But you would get a lot more for your money buying a 2nd hand higher spec camera with low use.
One of the higher model Nikon or Canon cameras costing the same price used as the new lower spec ones would still let you use the cheap wide angle lenses available for them. Unfortunately the other makes lack these cheap wide angle zooms so unless you can pick up a 2nd hand wide angle lens for them you still have the extra cost element.
If you can wait until November there is the chance of getting much better prices in the Black Friday sales coupled with the cashback programs the manufacturers run at that time of year (often double cashback so a nice saving to be had). You can find the prices for cameras and lenses at
www.camerapricebuster.co.uk
If you want to save a bit of money you could buy frrom the grey market at
HDEW or
Panamoz although at the lower price range they can sometimes be more expensive than buying from normal retailers. For the Canon 10-18mm HDEW is £189, Panamoz £260 vs the £199 most retailers are seling them at.
