Best cables?
Discussion in 'Cables & Switches' started by Colin Parker, Oct 7, 2004.
  1. Colin Parker
    Colin Parker
    £2500 Monitor Audio Gold speaker
    £500 Denon amp
    £1000 Sony RPTV
    How much should I spend on speaker cables and interconnects, and which ones are thought of as the best? I'm thinking QED.
  2. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Get them from Mark Grant on this forum :thumbsup:
  3. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Hi Colin,
    There isn't a real set price. Dealers will tell you 10% of your total budget. As for the best, well that's down to opinion and your own ear. Personally I like Atlas and Kimber interconnects. They aren't cheap but they do the job very well. As for speaker cable there are a lot of threads on this forum about standard twin and earth electrical cable. This is a good cheap option.
    If you don't mind a spot of DIY then CAT5 network cable is a good way to go. Slightly dearer but with greatly improved sonics. Again it's only my opinion but I doubt you'll be able to buy better for less than £50 per metre.
    HTH
  4. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    My standpoint is if it dosnt measure better then it isnt better. Read the post by beekeeper, its all you need to know. Cables neednt be expensive to be good :smashin:
