Best cables and where to buy
Discussion in 'Plasma TVs Forum' started by Dextur, Sep 6, 2004.
  1. Dextur
    Dextur
    Aug 30, 2004
    10,336
    +1,756
    Can anyone recommend the cheapest place to buy quality component cables from please? Online source needed.
    I need to hook up my plasma , dvd, etc
  2. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
  3. Dextur
    Dextur
    Aug 30, 2004
    10,336
    +1,756
    thx for that
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    3 strand av copper screened cables with red/black/yellow phonos either end do just as well and cost about £1.50 a meter. Component is a very robust signal and really doesn't suffer from degradation or crosstalk. (if you need a BNC rather that phone connection at either end then bnc to phono adaptors are about £1 each & you need 3)
    3 metre long, gold plated connectors, costs £4.50
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=57784
  5. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Be very careful using cables that *look* the same to do a different job. Many red/black/yellow cables will only have a single 75ohm core (since the other two are designed for audio). Cheaping out on cable will only strangle your system needlessly. If you're looking for component there's a guy in the Powerbuy forum making up decent leads using Belden cores and Canare plugs - can't recomend much better than those.
  6. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    I hate people talking [email protected]$ks about cables.
    Buy the cheap one, if you ain't satisfied with it buy an expensive one.
    Then kick yourself when you realise you been conned by a salesman
    with a 400% markup on silly priced cables. Let's face it online sales
    of plasmas don't make you much money, but if you can talk some mug
    into buying a few extra £70 cables, you laughing all the way to the bank!
    PS
    Phono/RCA connects were designed for audio only, BNC is the connect for
    video. If you gonna chuck away the design spec for the connects, you may
    as well forget the cable spec too.
    PPS
    Changing a cable spec from 75ohm to 50ohm is well within modern design parameters.
    PPPS
    If you want to be really picky, plug yellow wire to Luminance as it has a 1v peak signal, and other 2 wires to Component signals as they have 0.5v peak signals (not that it will matter anyways)
