Best cable to use the line-out socket on HD3 to play through my stereo?
Discussion in 'Headphones, Earphones & Portable Music' started by TommoK, Apr 14, 2005.
  1. TommoK
    TommoK
    Mar 9, 2005
    75
    Probably a dumb question but how do I play the tunes on my HD3 through my stereo?
    Whats the best cable to use the line-out socket and where can I get one?
  2. SP303
    SP303
    Right if your stereo has phono inputs (normally white and red) you just need a Twin Phono to 3.5mm Stereo Jack Lead which you can get here from maplins or from Dixons or any electrical shop.
    Just plug it all in and using line out it should all work fine. Line out is a fixed volume from your player so have the stereo on low to start and then turn it up to your required level :)
    If you dont have phono inputs on your stereo you can use a
    jack to jack lead and plug in via microphone input etc..
    Hope this helps :)
  3. gerbilly
    gerbilly
    Mar 20, 2005
    2,186
    Hamilton
    +94
    Get a good cable. Mark grant who is on this forum will be able to make a cracker for you for about 25 quid.
  4. TommoK
    TommoK
    Mar 9, 2005
    75
    Thanks guys :)
