Question Best cable for Sky Q and freeview
Discussion in 'Cables & Switches' started by mp3duck, Sep 3, 2018.
  1. mp3duck
    mp3duck
    Feb 28, 2006
    7
    I am currently building a new house, and need to run coax cable for both free view and sky Q.. what is best cable for both? I’ve read many different models and getting quite confused..
    I’ve seen PF100, NX100, WF100 etc.. I understand these are the same thing, basically a foamed filed cable .
    Some “SAT B” cable has been run already, but I can’t find much info on this one.. could be replaced if needed..
    Any help appreciate.
  2. neilball
    neilball
    Jan 7, 2005
    2,907
    Scottish Borders
    +640
    Webro WF100 or similar full copper conductor with copper stranded and copper foil shielding would be the ‘best’. Personally I’d avoid anything that uses copper clad central conductor or aluminium foil etc.
  3. giggsy1950
    giggsy1950
    May 27, 2007
    334
    +24
    I concur. WF100 works great and has less signal loss over the cable Sky use for installs. You'll need shotgun style cable (two cables running together in parallel) and anothet single length for Freeview. Don't get anything cheap and nasty!
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,389
    The Borders
    +3,436
    'and need to run coax cable for both free view and sky Q..' - just to confirm you are talking about Dish/LNB to Decoder or are you planning/pulling a network of cables within the house?
    Joe
  5. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,239
    +1,250
    Plus you need to look at what equipment you want to use if you want to send Sky Q and Freeview down the same cable like you could with Sky HD.
  6. neilball
    neilball
    Jan 7, 2005
    2,907
    Scottish Borders
    +640
    Once you’ve sorted your Sat and Freeview cabli got don’t forget to add in ethernet connections too - running wired network for Sky Q and Mini boxes, smart TVs, gaming consoles/PCs, wifi access points etc is also well worth doing and fairly easy to arrange when building the house. I’d allow for dual ethernet outlets at any location you are likely to have fixed equipment that can used it and keep wifi only for devices that have no wired connection available.
