Best cable for PS2
Discussion in 'Playstation Forums' started by Dade, Oct 12, 2004.
  1. Dade
    Dade
    Ive just ordered myself a Panasonic TH42PE30 plasma screen. I want to hook up my PS2 to the new screen but need to know what the best cable I can get for this is?
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    If you can afford it then the IXOS PS2 cable 30 quid from cable-shop.co.uk is awsome, loads better than the official Sony one (I've compared them both)
  3. Dade
    Dade
    will this be better than using a vga box and the vga socket on the front of the Panny?
  4. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Sorry can't help answer that I have no idea how good the RGB vs YUV is on the Panny. I think you'll only get progressive output through the YUV though, although there's only a few progressive PS2 games.
    Slingshot
  5. Throttle
    Throttle
    Sep 28, 2004
    1,823
    Leigh
    +107
