Best cable connection for un-modified Xbox?
Discussion in 'Xbox Forums' started by LMD, Jan 3, 2005.
  1. LMD
    LMD
    Dec 15, 2004
    231
    +5
    Can anyone advise the best cable option to get the most out of my un-modified Xbox?
    I am currently using the standard leads that come with it - assumption is that a decent quality RGB Scart lead would be the next best option to a fully fledged prog scan set up?
    Any pointers on relevant cable manufacturers also greatly appreciated.
    Thanks in advance :thumbsup:
  2. daveb975
    daveb975
    Oct 25, 2002
    4,346
    103
    London
    +371
    I have recently changed from the official advanced scart lead to the offical component lead, and it is a noticably better picture IMO.
    I am planning to soft mod my Xbox to make it progressive, and will hopefully get a better image still.
    If you have got a TV that can handle component, I would go for this cable (or the IXOS equivalent).
  3. LMD
    LMD
    Dec 15, 2004
    231
    +5
    Thanks for the response.
    I have found the following IXOS cables...
    http://www.tvcables.co.uk/cgi-bin/t...group/se=Gaming Cables/op=eq.html?id=jdjMkhTY
    Component video wont be an option as I am already using this connection on my TV for a DVD player. I do have a free RGB Scart input though so figured the Ixos Scart cable would most likely be the best option.
    Would appreciate any comments on this matter, cheers!
  4. LMD
    LMD
    Dec 15, 2004
    231
    +5
    Actually, think I am going to go with the official MS advanced scart lead.
  5. daveb975
    daveb975
    Oct 25, 2002
    4,346
    103
    London
    +371
    Thinking about it, you are probably best off with the MS lead - it has the option for an optical out connection, which the IXOS doesnt IIRC.
    I have an official MS Advanced SCART lead that you can have for £10 inc if you are interested.
  6. LMD
    LMD
    Dec 15, 2004
    231
    +5
    Thanks for the offer but have already ordered one! If I have any problems with the order I'll be in touch ;)
  7. jerkyboy
    jerkyboy
    Forget the IXOS cables, you cant get Dolby Digital with them The doughnuts have not included an optical output on any of there leads !!!!.
    I have had both Monster cables (very expensive) and the official Mucrosoft cable, I could not tell them apart.
    Go for the official one.
